Angle Dimension Format Bug
I’m trying to dimension an angle in DMS format rather than degrees.
First I draw two lines, Dimension -> Angle Dimension -> click on the two lines -> click where the dimension should go. The dimension is in degree format, so I go to Dimension -> Dimension Styles -> and change Angle Format to DMS under the Text tab. When I close the Dimension Styles box, my dimension disappears. The arc is still there, but no angle dimension. If I change it back to degree format, the dimension reappears.
Should be a pretty easy bug to reproduce, but I made a video of it just in case: https://youtu.be/7WdDzzeup74
Software information
Software versions
Rhinoceros version: 5.3 (5D191)
IronPython version: 5.1.2015.131
Language: en (MacOS default)
macOS version: Version 10.11.6 (Build 15G1217)
Plug-ins
None
Third party kernel extensions
None
Hardware information
Computer hardware
Hardware model: MacBookPro9,2
Processor: Intel Core i7-3520M CPU @ 2.90GHz
Memory: 8 GB
Architecture: Intel 64 bit
Video hardware
Graphics: Intel HD Graphics 4000 1536 MB
Memory: 1536 MB
Screen size: 1280 x 800
Displays: Color LCD (114dpi 1x)
USB devices
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Computer, Inc.: IR Receiver
Apple Inc.: Bluetooth USB Host Controller
Apple Inc.: FaceTime HD Camera (Built-in)
Logitech: USB Laser Mouse
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 INTEL-10.14.73
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: 4x
Mip map filtering: None
Anisotropic filtering: None
Hi Jeff - thanks, I see that.
https://mcneel.myjetbrains.com/youtrack/issue/MR-3036
This should be fixed in the next RhinoWIP. I will post again when that is available. Thanks again for reporting this!
This item should be fixed in the latest RhinoWIP (5E41w). Please give it a try.
