I’m in Rhino 7 (Windows), I need help figuring out where I’m going wrong. Trying to use the Angle command, and it works for some angles, but for others the result doesn’t make sense. I have a video attached of the issue, and you can see how a normal right angle reports measuring 90° but the other angle that should measure a lot more than 1, measures 1.506. While I acknowledge that the angle measurements of course add up to 180°, I just am confused as to why those measurements seem off. What am I missing?
Thanks,
jricha
