I’ve recently started to use grasshopper and RiR. First of all, it is a great plugin and extremely useful, so congrats!
I am a structural engineer and it would be amazing if you could add for the next versions some boxes to add loads to beams and floors. It is really tedious to add loads in revit, and if there would be the possibility of adding the loads from grasshopper it would be great.
I usually export the geometry from Revit to ETABS/SAP2000 and then I add the loads there. However, if there are any changes in geometry I have to add the loads again. If there would be the box of loads this process would much more easy and fast.
I know… That’s why I said it would be great if you could add the option that Revit has of adding loads.
I’ve tried Salamander 3 to export the model from GH to ETABS or SAP2000 but it doesn’t work. I sent an email but i don’t have an answer yet…
