Creating Loads and Load Cases using Rhino inside Revit
Hello Guys
please tell me how you can create load and load cases using rhino inside revit.
I know how you can see it in a project, but how can you add loads on slabs, walls, columns, beams to the Revit file?
Hi Foxman, we have a feature request for adding additional components Point Load, Line Load, or Area Loads, …
The current native components for structural elements…
What is available via the Revit API
https://help.autodesk.com/view/RVT/2024/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Discipline_Specific_Functionality_Structural_Engineering_Analytical_Model_html
Thank you very much for the detailed answer, I will be waiting for these nodes, they are very necessary in my work!)
Japhy
Do I understand correctly that if I have a load in Revit, then I can change the intensity in it through Rhino Inside and it will change in Revit?
or can’t this be done? Is it possible to manage the parameters of a load family using Rhino Inside? I can’t find the intensity (magnitude) of the load for this family?
You should be able to get/set those values, the tricky part is the Unit conversions
Japhy
rays of gratitude for the answer
I figured out how to change the load value !!!
but I didn’t understand about changing units of measurement…
I have a linear load in Revit kH/m, but through Rhino Inside I see some other values, I see them in kg/ft ? although Rino Inside writes that they are also in kH/m
or am I misunderstanding something ?
