I’m pretty new to rhino/cad software so go easy. I have tried a search for the issue/tutorial but no luck.
I have imported a dwg into rhino and want to add dimensions to it, I selected the linear dimension option.
Once I have done the three clicks no dimension shows. Any ideas? Also found not all the detailing shows.
Is this a dwg to rhino issue does something need to be changed in preferences? oh and its on a mac.
The dimension option works if I start a new document. Its a supplied auto cad dwg that just won’t work, I need to add dimension for my construction drawings and time is tight.
You’ll need to take the time to learn about named dimension styles and the settings that control how they look, or get some help from an experienced Rhino user, perhaps on a consultant basis to meet your time constraints.
OK, so there were some existing dims - what I’m after is finding out if your new dims exist at all - l ike John, above, I have a feeling they are there, and you need to change the sizes or something.
Try - SelDimLock. Make your new dim, then SelDim again - anything reported selected?
You’ll want to have a look in FIle > Settings > Dimensions and see what styles are available and fuss with these - modify to taste to get things sized correctly for your situation.
This seems like the text and arrows are just really small. Are you placing the dims in model space, or layout space? If you are placing them in model space, you may want to change the model space scale. If you are placing them in layout space, be sure that the dimension’s layout sizes seem correct.
