I tried to dimension, but it is not showing the dimension, only a rectangle(yellow
)maybe the text is too small compared to the model size, check the dimmension properties under rhino options.
… and if those setting appear to be fine and you still cannot see the dimension values, please run the Rhino SystemInfo command and post the result here.
