I’m trying to get my head around rhinoinside currently trying to push steel beam geometry from rhino into Revit that is essentially a beam with some holes in it.
I tried direct shape but it is wrought with issues of not properly coming into Revit.
So I was hoping there was a way to set it up in rhinoinside whereby you specify a beam, attach holes to it using lines or parameters on the beam (basically automating Revit beam and hole creation).
I’m almost certain there is a way in Revit API to pull this off but I have no idea how.
Here is a file sample I’m working with:
Thanks for looking at this.
“Perhaps placing a family on the beam axis with parametric voids that can be used to cut the beam?”
Would you be able to provide a simple example?
Thanks for your help!
How would you go about creating custom beam and hole families in GH (without creating and referencing Revit objects)? Is it possible?
@Japhy perhaps you can help me with a similar problem, even though this is an old topic. I need to cut rectangular holes of different sizes in structural beams in Revit using RIR.
When I use a generic void model, the void is placed correctly, but not cutting any geometry. I will have to do this manually using Revit’s cut tool.
When I use a face based generic void model, I get the error “Can’t rotate element into this position”. The void component works fine when placed manually in Revit.
I have seen a couple of different topics with related issues, but most of them are regarding wall-hosted geometry. Any advice?
I can provide an example and/or screenshots if needed.
Thanks in advance!
The last custom component in the GH file attached in the below reply takes the void element and the solid element you want to cut, and applies the cut, so you don’t have to cut them manually in Revit.
Thank you @M.Tarabishy! This is a great solution.
Your example also taught me the use of the Component Family Void component, which could be a better and easier solution than an adaptive void family in some cases.
