Hi Mohamed, it is place outside the viewport or inside the sheet space, thanks.
Revision Tags should be placed in the View, with the Annotation crop used in the sheet if need be.
I solved all of the mentioned issues before, still the component ByLocation is not working when the curve is in 3D (not planar). It keeps giving the warning “Can`t rotate element into this position”.
And the python script is only for elements already computed by the component ByLocation.
Do you know how to place families, when you have a curve in 3D? Thank you.
Hi Bianca,
In your Revit Family is the Always Vertical checked? You’ll want to be WorkPlane based and Not Always Vertical
Thank you Japhy. I managed, but after I loaded the family and I set those parameters inside GH. If the family was just used and the parameters set in RVT, the elements weren`t computed.
I’ll need more information to be able to help. Can you make a simple example & send the files? Thanks.
Cant find
Can’t find what?
Do you understand this reply by Japhy?
