Hi all,
i have a set of curves (horizontal and vertical in black) and i would like to connect them as showed in the picture (with the blue curve). There is some command that do it automatically in grasshopper ?
Shapes could be whatever, not just square or round objects
Hi, thank you for your reply, but I would like to create the blue curves with grasshopper using the black curves.
In the picture i attached, I drew the blu line by myself in Rhino to show what i needed.
Connect Curves with ‘G’ input set to ‘Position’ (using right-click). But this requires alternate curves to be flipped first so their end / start points are near each other.
3. Attach minimal versions of all the relevant files
