In Grasshopper is a node called Connect Curves (Picture) is in rhino common a similar command?
Any help is welcome.
Thanks in adcanced
Thanks in adcanced
to connect curves i use in the end blend curve in a recursive function and join blend curves and blended curves together like this.All curves are already sorted with the shortest distance to each other.
# create blend curves between the BrepEdge gaps
ta = rh.Geometry.BlendContinuity.Position
CU=[]
n = 0
def CON(n):
if len(CU) == len(L)-1:
return False
CU.append(rh.Geometry.BrepEdge.CreateBlendCurve(L[n],L[n+1],ta))
return CON(n+1)
CON(n)
# combine BrepEdge list with BlendEdge list and join all Edges
CC = CU+L
CJ = rh.Geometry.BrepEdge.JoinCurves(CC)
Hi @flokart,
The Connect Curves component uses both Curve.CreateBlendCurve and Curve.JoinCurves.
ā Dale
Thanks dale for the info.
