Hi, In Options\ModelingAids\Behavior when all are selected ,the Distance is shown while inside a command.
For example when I scale 1d or measure distance the distance does’nt apeare in real time in the small white rectangle (like in v6 & v5) only when I finish the command it shows the distance in the command prompt
Can that be fixed?
Thank you
Solomon
Hi Solomon -
I can’t get this to behave differently from Rhino 5 on my PC.
This is a screenshot doing Scale1D on Rhino 7:
Note that when you snap to an object, you will only get the snap name in the tooltip - but that behavior was the same on Rhino 5 and 6.
Thanks, It got fixed don’t know how (my be my mistak)
