Hey McNeel,
Just noticed that the distance tooltip doesn’t show when using the _Dim or _DimAligned command.
Thanks,
Aaron
Hey McNeel,
Thanks,
Aaron
Hi Aaron - would you expect the actual 3d distance or the dimensioned distance, when these are not the same?
Hi Arron - yeah, the slightly weird thing though, and I understand that it is not an issue at all in 2d, is that the distance may not correspond to the dimension, so I’m not sure what should happen- maybe it’s fine as in V5 but it seems like it might be confusing.
I just find it handy to find the measurement I want to snap to - understand if that sounds counter-intuitive!
