I’m using the ‘Set multiple linked graphical elements’ setting in the ‘Graphical element’ component but I am getting these error messages. There isn’t much information provided such as the element’s ID or why it could not be found. If I’ve selected it from a view, one would expect it can be found.
Which exact version of RiR are you in? I just tested in the latest and not seeing anything unusual in getting linked elements via Graphical Element. I’ll test in your version too.
If I use the model I have and reference the linked model, it fails (Set multiple linked graphical elements)
If I remove the link and relink the model and reference it, it fails.
If I start a new project and link in the model, it works.
The file may have originated from BIM360. Could this ‘setting’ be embedded into the model somewhere and therefore RIR is rejecting it?
There doen’t appear anything special with the model - just a workshared model on local drive. No design options enabled. I’ve tried with and without shared coordinates. Phase mapping is the same in both models.
Any other thoughts as to why this might be failing?
Edit: this is in response to Japhy’s quoted post above.
I believe this is dependant on what version of Autodesk Desktop connector is installed. After ~ version 14.8 it changes the names of directories from BIM360 to ACCDOCS.
I can confirm I am using an older version of desktop connection which is still using BIM360 directories when getting the issue and should not be related.
The issue is that Building A was saved as Building B (or vice versa) the result being is they have the same internal DOC id. No behind the scenes fix it looks like, we are testing a few things.
Linking into a new file and binding is one option, but really depends on the workflow you have going.
