Issues with BIM360
Files on BIM360 can be tricky for RiR. Below are some buggy outputs I feel may related to BIM360. I am not sure if they are on the “bug to be fixed list” or not. If they are, please just ignore me.
  • “Graphical Element” can’t pick linked element.
  • “Document” ignores the selection and only returns the active document when multiple model opened.
  • “Visible In View Filter” returns incorrect boolean.
    It is for this primary one.
    Local file works well, but when it is in BIM360, it doesn’t return linked elements.
    Can you provide steps to repeat this?
    I have 2 model opened from BIM360, doesn’t matter which one I chose, it returns the active one.
    Parameter Filter Doesn’t Take Element ID - #8 by kike
    Yep, this one we have already discussed. However, the altertive solution takes like 3-10mins to run for each check. Just trying to double check if it is possible to fix the bug with BIM360 you mentioned.
The only time #1 has happened is per that thread, where the central file was saved as from the original file and the have the same internal document #. I’m running 1.11 and there is supposed to be a fix soon.
Not able to repeat the second item. Is there something i’m missing?
Don’t know what happen to BIM model of my project to be honest. It is a combination of several nasty models. I am guessing if how it shows from my side is because of recursion links (not suer if it is the right terminology for nested links).
