nathanletwory
(Nathan 'jesterKing' Letwory)
May 21, 2018, 5:39pm
21
Changes for release candidates are always posted on Serengeti, like this
Rhino 6 SR5 Release Candidate 1 (6.5.18128) is now available.
To get it, subscribe to the Release Candidate update stream .
New in SR5 RC1:
Crashes fixed:
CPlane: RhinoCore!CCommandCPlane::SetNewCPlane – Access Denied (MERGE) (RH-45734 )
Core bugs: InsertKnot Command: RhinoCore!CRhGetInsertKnotCurvePoint::OnMouseMove – Access Denied (RH-45678 )
No Subsystem: :UseRhinoFont – (NTSTATUS) 0xc0000094 - {EXCEPTION} Integer division by zero.(MERGE) (RH-45714 )
Options: Advanced option list crash (RH-…
Changes for the final service releases in the main forum like this
Rhino 6 SR4 (6.4.18124) is now available.
Rhino will download and offer to install these updates for you, unless you’ve disabled automatic updates.
New in SR4:
Crashes fixed:
BooleanUnion: Opennurbs!ON_Brep::AddEdgeCurve – Access Denied (RH-45408 )
Cycles: Crash when shader ID not found (RH-45536 )
Display: Crash dragging splitters between parts of display (RH-45423 )
No Subsystem: :UseRhinoFont – (NTSTATUS) 0xc0…
Just follow the forums for your information.
Elshar
May 21, 2018, 5:44pm
22
I try my best to always be in the forum. But I’d like it more to be attached as a note file with the download link, so I can check it when I am offline,
Thanks Nathan,
Elshar
nathanletwory
May 21, 2018, 5:51pm
23
Elshar:
the download link
What download link are you referring to?
Elshar
May 21, 2018, 5:56pm
24
The one you download from the update checking page!
nathanletwory
May 21, 2018, 6:02pm
25
Thanks, there are many locations with download links, so it was important to figure out which you meant.
I’ve logged a request here https://mcneel.myjetbrains.com/youtrack/issue/RH-46195
Hi Elshar. download FARSI NEVIS ROSE 1.4 from food4 rhino : this is the link:
Farsi Nevis Rose 1.4 | Food4Rhino
ismail_M
(ismail M)
July 23, 2023, 11:12pm
29
Hi george How to intall it on mac please?
Hi Ismail I don’t know if it work on Mac . But here is another program but not plugin. You can install and write the text and copy the results on rhino. Tadween :
Arabic text example :الغزال جميل the result on Tadween program is: ﻞﻴﻤﺟ ﻝﺍﺰﻐﻟﺍ copy and paste the result on rhino text.
