A Problem with Auto Intersection and Add Interference
Auto Intersection and Add Interference are shown on lower level when the plan visibility for upper level slabs are set to “Projection and Overhead”.
On lower level floor plan, only the outline of upper level slab should be visible as hidden line.
Thanks.
Hi @Steven_Kim you are right, the intersection lines of the slab and the stair and the walls should not be visible in the lower level. We study how to fix this.
