A Helpful Material Mapping/Application Texture
Yes consider: [UVEditor TIP] UV mapping: Replace your UV Grid Texture
Put to the right and bottom edge a white outline into the texture. This will help you to define when you are out of the UV space. Also consider adding circles in each small square.
