After I changed the display text of a angular dimension in rhino6&7, then export it to dwg file. The dimension text will show a unreadable text in AutoCAD. Even though I could do it by switching to Rhino5, Wish to solve it in rhino6 or 7, thanks.
Could you please explain the “changed the display text” part of that?
When I export an angular dimension to DWG and open that in Autodesk DWG TrueView, that seems to work without issues.
