When using the 4 Default Viewports button in v8, it’s resetting the viewports but not back to the default layout… ‘Left’ is in the top right, ‘Perspective’ in the bottom right, ‘Front’ is top left, ‘Top’ is bottom left.
Anyone else experiencing this? The button macro is: '_4View ZEA
Hi Aaron,
You have the Projection option in the command set to FirstAngle. Change that to ThirdAngle and I think you will see what you expect.
If I’ve misunderstood, please expand on the problem.
HTH
Jeremy
PS. To get at the option you may need to type the single command _4View instead of pressing the button.
You’re absolutely correct, thank you!
I’ve updated my macro to '_4View ZEA Projection=ThirdAngle Enter
