3dconnexion SpaceMouse - wrong bindings
Looks like the 3dconnexion settings have moved to a plugin in RhinoWIP. I have not opened it for a few months but wanted to test something out. Previously the axes setup was identical to Rhino 8 but it seems to now have changed - default mouse in/out used to zoom in/out but now changes the camera Z position. I tried customizing in 3dconnexion in the macOS preference panel after adding RhinoWIP as an application, to no avail. Tried disabling/enabling the plugin and a few other basics.
Sorry if this is already a know issue; figured I’d chime in just in case!
Are you aware of the _SpaceMouse command?
I saw it in other forum posts, but I don’t see it locally, alas:
Hmmmm that might be due to your operating system. Sorry no idea why the command is not available there…
it’s a Windows Rhino only
Hi Luke -
There’s a bit more information in this post:
Thank you @wim , I did search around the forum but somehow didn’t find that post. I’ll keep an eye out for fixes.
Cross-posting here, just in case:
