3d connexions space mouse doesn't work correctly in Rhino 9 wip mac
My 3d connexion spacemouse compact works perfectly with Rhino 8 but in rhino 9 wip it works but the control is all mixed up.
Anybody know how to fix it?
Moved to Serengeti (Rhino WIP) Mac category.
Have you tried the solution mentioned here?
Cross-posting just in case…
Again, cross-posting here, just in case:
I know ,it’s really annoying .It tilts instead of rotating. I have been trying to get someone to fix it for months. I can not justify this new version without it working properly.
It’s broken in Windows as well
ok im glad its not just me. just upgraded from r6 to r8 and the sp-nav mouse control is a bit strange. most notably the roll/ l-r tilt is non functional. sometimes it rotates, sometimes it does nothing. i had to turn that off in the 3dxware. also some of the directions needed to be swapped from what they normally are but then they started working correctly again and i had to switch it back. very strange. also seems like some of the movements are switched if moving around under the world plane vs above it.
type in Spacemouse, select popup_menu, select Object Mode, Fixed it for me on Windows
Also check rotation
thanks. i am already in object mode and i have tried them all.
