3dconnexion mouse stop working in latest rhino wip
Hello. After updating to the latest Rhino WIP, the 3d connection mouse no longer works. I uninstalled and reinstalled the 3D Connection drivers without success. Aby idea how to fix that?
In Rhino 8 options, I see the 3Dconnexion SpaceMouse option:
In the latest Rhino WIP, I no longer see that:
Thank you.
Have you seen this?
Thank you.
Hi I have been struggling with the space mouse for a few week in the wip, it works perfectly in 8 the
Rhino.Options.SpaceBall.UseLegacy does help but the up down z axis is still linked to the zoom so a little janky for me would be great to resolve.
Correction the use legacy does not correct the issue I have currently with the space mouse all the axis seem mapped incorrectly is the best way I can describe my issue. up down is zoom in out Spin clockwise / anti clockwise is tilt the only thing that works was expected dolly / in & out tried remapping in the 3d connection pane but makes no difference and works perfectly in rhino 8 please help.
Try this: use SpaceMouse command and use popup option, change to camera mode…
Unfortunately I get : Unknown command: SpaceMouse
In Rhino WIP, Enable Rhino.Options.SpaceBall.UseLegacy, restart Rhino.
After restart, check the 3dconnexion plugin in Rhino is actually enabled, otherwise enable it and restart Rhino.
If now SpaceMouse command doesn’t exist again, I have no clue.
Maybe the plugin isn’t loaded?
Maybe a Mac thing
Something Definitely weird happening after restarting when use legacy active im able to pan and tilt in the orthographic view as well ! .
Rhino 9 SR0 2026-6-9 (Rhino WIP, 9.0.26160.12306, Git hash:master @ 193b2bed280be6369fe07ebda036f618870d329e)
License type: Commercial, build 2026-06-09
License details: Cloud Zoo
Expires on: 2026-07-24
Apple macOS Version 26.5.1 (Build 25F80) (Physical RAM: 128GB)
Mac Model Identifier: Mac16,9
Language: en-GB (MacOS default)
.NET 10.0.2
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M4 Max
Studio Display (2560 x 1440 @ 60.00Hz)
BenQ PD2705Q (2560 x 1440 @ 60.00Hz)
GPU Vendor: Apple
USB devices
Generic: 5-Port USB 2.1 Hub
Apple: USB3 Gen2 Hub
3Dconnexion: SpaceNavigator
Apple Inc.: Studio Display
Apple Inc.: Magic Keyboard with Touch ID and Numeric Keypad
Apple Inc.: iPad
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_DarwinFoundation1.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswift_DarwinFoundation2.dylib
/usr/lib/swift/libswift_DarwinFoundation3.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/swift/libswiftsys_time.dylib
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswiftCoreMediaIO.dylib
/usr/lib/swift/libswiftCallKit.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/updaters/libAppleTconUARPUpdater.dylib
/usr/lib/updaters/libT200Updater.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Library/Frameworks/3DconnexionNavlib.framework/Versions/A/3DconnexionNavlib
/Applications/RhinoWIP.app/Contents/PlugIns/3DxRhino.rhp “3DxRhino.9” 9.0.26160.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 9.0.26160.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 9.0.26160.12306
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 9.0.26160.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 9.0.26160.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 9.0.26160.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 9.0.26160.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 9.0.26160.12306
/Applications/RhinoWIP.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 9.0.26160.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 9.0.26160.1002
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 9.0.26160.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 9.0.26160.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 9.0.26160.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 9.0.26160.12306
A bit of cross-posting here: SpaceMouse not working in WIP - #18 by dan
