Water shape made by boats when moving
Hello everyone how would i approach creating something like this please? thanks!
Here is a thread on this:
Here is the same image but as a BW texture and blur filter.
thank you guys but i want to create something like this in grasshopper!
You can do it in grasshopper by using graph mapper then repeat data connected with move in Z axis . then use loft between all curves :wink:
i have been trying for an hhour yet this is as far as i could go! could you please help me out !? thank you so much!
help.gh (448.7 KB)
Ok, just to let you know.
There is a displacement, and here is the setup.
thank you sir , but im trying to make it in grasshopper is there any way i could do it? also can you please send me the rhino file you made? looks super interesting
ive been trying to create it in grasshopper using image simpler but i couldnt somehow i dont get it
help.gh (449.7 KB)
I know this is not what you are looking for, but this material can be handy for visualization later.
the material
Waves.3dm (726.9 KB)
It is ready to use :slight_smile:
Wave System.gh (462.9 KB)
Eight years ago I used an Image Sampler to create surfaces with wake patterns, including additional waves outside the pattern.
Here are 22 of the GH files I can find from that period:
wake_wave.zip (4.2 MB)
And this old video that looks like the source of some of your images?
I’ll use the formula presented in this shader.
Looks cool, what’s a “shader”? Does it create surfaces or only illusions?
Care to post a GH example?
I am on it. Just began
Here I understand the shader is doing some black and white. using some parameter (mouse position)
A more simple one .
Example of shader application
Not there yet, but seems encouraging
Still some work to do to tune to Grasshopper, coordinates in Shadertoy seems between -1 to 1, some others values could be changed to change the scale …
Some Nautilus Component to color the mesh or bump but could be replaced by some GH components.
Output A is a double value for each mesh vertex.
kelvin wake legacy.gh (10.3 KB)
thank you so so much!!!
:frowning: Looks promising.
missing
Tells the guy that sends 22 definitions :thinking:
None of them required plugins, eh? I looked through them, couldn’t decide which one was best.
Like I said the C# doesn’t need plugin it was just a way to visualize the results.
kelvin wake special for Joseph.gh (11.5 KB)
No thanks.
