3d Voronoi inside Spiral
Dear Members…
to finish my architectural project, I need to fit the voronoi cells inside the spiral pipes.
In other words, How can I replace the box component with the Spiral Pipes? (each pipe having a 3d structure inside.)
Thank you so much in advance.
Voronoi Help.gh (9.9 KB)
Voronoi.3dm (638.9 KB)
just put a Brep component instead of a Box component
Thank you for the quick help Baris.
I have tried that … but never creates regular voronoi cells within the pipe. this is what i get:
this is the type of environment I am trying to create in the spiral tower using Voronoi Cells.
I thinkto archieve this with your Geometry will be a little bit difficult as it is twisted, it will probably fail everytime there to create a closed mesh
I just tried the definition you posted and it worked on the pipes!
however, I draws only 2D Voronoi. I need 3D (interior cells) not only on the surface of the pipe. (I dont want it to be hollow)
Is that achievable?
Is there anyway to turn the pipes into a solid region? (it is capped but still considered a polysurface.)
Voronoi.3dm (959.8 KB)
I tried it with your Geometry but it failed, I think you have to get rid of the twist:
I try to reduce the twist. Thank you sooo much for your time and effort.
Hello there, at the end did you find a way to make the voronoi geometry inside the pipe?
I am trying to achieve a similar design…
Voronoi Spiral Pipe V0.gh (9.8 KB)
here
Thank you for your reply. It seems the voronoi is only happening on the outer surface though. The original aim I think was to have the voronoi going inside the volume as well. So that multi-pipe could then be applied to it.
wow this looks really cool Quan!
:slight_smile: i know the Voronoi All-in-One Master @HS_Kim can help you.
Just use Populate 3D instead of Populate Geometry.
3d-voronoi-inside-spiral.gh (179.4 KB)
