Multipipe on surface, using Voronoi 3d grasshopper
Hi All
I need some help. I am trying to create a 3D Voronoi tessellation on the surface and inside of a brep or mesh. It seems that I can only create the tessellation internally using Voronoi 3d or on the surface . I don’t know how to combine them or how to find the shortest distance (curve) between two points on a mesh when all I have is a point cloud. I know I can use point on mesh but I am stumped.
I have attached a file with my current progress. Ca
n anyone please give me some advise.
Multipipemeshvornn.gh (15.4 KB)
Multipipemeshvornn Edited V0.gh (18.3 KB)
I believe this is a known bug. Scale it down or try Dendro to smooth it out.
Hi @Quan_Li
I posted this as I left work and as soon as I got home half an hour later, I saw that you had solved it!!
Thanks so much and Ill be aware of that issue in multipipe expecially since we will eventauly machine it.
Wow :open_mouth:
Post some pictures when that happens.
This kinda looks ‘volumetric’ :face_with_monocle: :thinking: :thought_balloon:
I’ll have to compare this approach to some others, and see the similarities and differences.
