Hey guys,
I faced the image
and i wonder how to distort my 3d grid,
I’ve tried with noise4d or fields but no success due to the fact that the points need to connect in the same order.
any ideas?
thanks
try pufferfish
hey Mohamad thank for the recommendation,
can you think about which component in puffer fish will help?
i made the 3d grid with dots and i found the closest points to deform the problem is to make the lines connect like this.
I will try it thanks a lot.
I meant that my problem was to connect again the lines after moving the dots, but i will try you solution. thanks Laurent.
