Script "_Dir" Command in Rhino5
Hi there,
I have successfully written a script in Rhino4 that contains the following line:
Call Rhino.Command("_Dir F S _Enter")
It flips the directions on a surface and then swap them. This works nicely.
For some reason, this command does not behave in the same way in Rhino5: the S command does not swap the direction but it turns on the grid snap on.
What should be the statement to swap the uv coordinates in Rhino5??
Thank you
I think it should be:
Call Rhino.Command("_Dir _F _Enter")
This will already flip the dir.
Call Rhino.Command("_Dir _SwapUV _Flip _Enter")
If use:
I have the following statement:
Unknown command: _SwapUV
That’s odd. Do you have this option on command line?
This happens if you start your macro but have no surface(s) preselected. The _SwapUV command line option is only available inside the _Dir command. To avoid that, you can use _Pause after _Dir, so rhino waits for selection and then starts over if you have something selected and ended your selection with Enter (or right mouse button).
_Dir _Pause _SwapUV _Flip _Enter
It still works in one shot if you have one or more surface(s) preselected.
c.
I found my problem: in my selection I had a point and the surface selected. I had to make sure I select the surface only:
		Rhino.Command "_-SelNone", 0 '
		Call Rhino.ObjectName(obj, SurfaceName)
		Call Rhino.SelectObject(obj)
This works fine.
Thanks for your help.
