Is there an equivalent function to the Dir command in Rhino 5. I want to check the line direction and flip it if need be.
The Dir command exists in V5… you can script it with rs.Command().
Is there a way to get the direction normal and flip it if necessary? I know you can do this in the Rhino window but I want to do this in the background with code.
Sure, get the tangent vector (rs.CurveTangent) somewhere along the curve… rs.ReverseCurve() will flip the direction.
I found the code pasted below in API examples. This works for me. I’m just trying to wrap my head around the logic. Why does the curve have to be duplicated and replaced? Can you simply just reverse the direction of the original curve?
from scriptcontext import *
import Rhino
def ReverseCurves():
crvs = rs.GetObjects("Select curves to reverse", rs.filter.curve)
if not crvs: return
for crvid in crvs:
crv = rs.coercecurve(crvid)
if not crv: continue
dup = crv.DuplicateCurve()
if dup:
dup.Reverse()
doc.Objects.Replace(crvid, dup)
if __name__ == "__main__":
ReverseCurves()
dunno if this is useful, but here’s a script that will change all the curves to be cw or ccw
Option Explicit
'Rhino.AddStartUpScript Rhino.LastLoadedScriptFile
'Rhino.AddAlias "SetCurvesClockwise", "_NoEcho _-RunScript (SetCurvesClockwise)"
Call SetCrvDir()
Sub SetCrvDir()
Dim aCrv, sCrv
aCrv = Rhino.GetObjects("Select closed curves", 4,, True)
If Not IsArray(aCrv) then Exit Sub
Dim blnDir, aDir
aDir = Rhino.GetBoolean("Set curve direction.", array("CurveDirection", "Clockwise", "CounterClockwise"), array(true))
If not IsArray(aDir) then exit sub
blnDir = aDir(0)
dim n: n = 0
for each sCrv in aCrv
if Rhino.IsCurveClosed(sCrv) then
MakeCrvClockWise sCrv, blnDir
n = n + 1
end if
Next
dim sDir: sDir = "clockwise."
if BlnDir = True then sDir = "counterclockwise."
if n = 1 then
Rhino.Print " 1 curve set to " & sDir
else
Rhino.Print n & " curves set to " & sDir
End If
End Sub
Function MakeCrvClockWise(sCrv, blnDir)
dim aLine, pt, vectan, aBB, aInt, n, Tol
dim temp, xform
Tol = Rhino.UnitAbsoluteTolerance()
n = 0
xform = Rhino.XformPlanarProjection(Rhino.ViewCPlane())
temp = Rhino.TransformObject(sCrv, xform, true)
aBB = Rhino.BoundingBox(temp, Rhino.CurrentView())
aLine = array(aBB(0), aBB(1))
aInt = Rhino.LineCurveIntersection(aLine, temp, Tol)
If not isArray(aInt) then
Rhino.DeleteObject temp
End If
if aInt(0, 0) = 1 then
pt = aint(0, 1)
else
pt = aInt(0, 3)
End if
vecTan = Rhino.CurveTangent(Temp, Rhino.CurveClosestPoint(sCrv, pt))
if blnDir = False then
If VectorAngle(Vectan, array(1, 0, 0)) < 90 then
Rhino.ReverseCurve sCrv
end if
else
If VectorAngle(Vectan, array(1, 0, 0)) > 90 then
end if
End if
End Function
Function VectorAngle(Vec1, vec2)
Vec1 = Rhino.VectorUnitize(Vec1)
Vec2 = Rhino.VectorUnitize(Vec2)
Dim DP: DP = Vec1(0) * Vec2(0) + Vec1(1) * Vec2(1) + Vec1(2) * Vec2(2)
If DP > .999999 then
VectorAngle = 0
ElseIf DP < -.999999 then
VectorAngle = Rhino.ToDegrees(Rhino.Pi())
Else
VectorAngle = arcos(DP, False)
End If
End Function
Function Arcos(dblAng, blnRad)
'dblAng input in radians
If BlnRad = True then 'output in radians
Arcos = Atn(-dblAng / Sqr(-dblAng * dblAng + 1)) + 2 * Atn(1)
Else 'output in degrees
Arcos = Rhino.ToDegrees(Atn(-dblAng / Sqr(-dblAng * dblAng + 1)) + 2 * Atn(1))
End if
End Function
