• run _ClosestPt
• select the box at first prompt (target)… press enter
• in the next prompt, choose the Object option
• select the line
• crash
the command works if both objects are a line and i guess it’s not meant to be used with a polysurface & line?
still, i don’t think it should crash like that.
or it works as in -
the command actually finds the closest point between the box and the line?
(ie, i’m not entirely sure of all the situations the command is supposed to work in but according to the documentation and prompts… it does seem like it should work with the example file)
on a side note, the crash also happens (on mac at least) when using rs.CurveClosestObject in python…
which are apparently providing similar functionality.
