hello,
is there a command to find the closest polysurface/text… to a point in rhino scripting (python)?
thanks,
CG
hello,
thanks,
CG
Some implementations has example code, including Python code:
https://developer.rhino3d.com/api/RhinoCommon/search.html?SearchText=ClosestPoint
Example for Surface (scroll down to see Python code):
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Surface_ClosestPoint.htm
// Rolf
thanks rolf!
There is also PointClosestObject:
https://developer.rhino3d.com/api/RhinoScriptSyntax/#collapse-PointClosestObject
that’s what I was looking for, big thanks, jess
That interesting wonder if RhCommon also has it Can’t find anything … For RC probably just checking distances to bboxes would me the smartest approach.
I don’t think so. If you dig into the rhinoscriptsyntax you’ll find this function:
def PointClosestObject(point, object_ids):
"""Finds the object that is closest to a test point
Parameters:
point (point): point to test
object_id ([guid, ...]): identifiers of one or more objects
Returns:
list(guid, point): closest [0] object_id and [1] point on object on success
None: on failure
Example:
objs = rs.GetObjects("Select target objects for closest point", 63)
if objs:
point = rs.GetPoint("Test point")
if point:
results = rs.PointClosestObject(point, objs)
if results:
print "Object id:", results[0]
rs.AddPoint( results[1] )
See Also:
CurveClosestObject
object_ids = rhutil.coerceguidlist(object_ids)
point = rhutil.coerce3dpoint(point, True)
closest = None
for id in object_ids:
geom = rhutil.coercegeometry(id, True)
point_geometry = geom
if isinstance(point_geometry, Rhino.Geometry.Point):
distance = point.DistanceTo( point_geometry.Location )
if closest is None or distance<closest[0]:
closest = distance, id, point_geometry.Location
continue
point_cloud = geom
if isinstance(point_cloud, Rhino.Geometry.PointCloud):
index = point_cloud.ClosestPoint(point)
if index>=0:
distance = point.DistanceTo( point_cloud[index].Location )
closest = distance, id, point_cloud[index].Location
continue
curve = geom
if isinstance(curve, Rhino.Geometry.Curve):
rc, t = curve.ClosestPoint(point)
if rc:
distance = point.DistanceTo( curve.PointAt(t) )
closest = distance, id, curve.PointAt(t)
continue
brep = geom
if isinstance(brep, Rhino.Geometry.Brep):
brep_closest = brep.ClosestPoint(point)
distance = point.DistanceTo( brep_closest )
closest = distance, id, brep_closest
continue
mesh = geom
if isinstance(mesh, Rhino.Geometry.Mesh):
mesh_closest = mesh.ClosestPoint(point)
distance = point.DistanceTo( mesh_closest )
closest = distance, id, mesh_closest
continue
if closest: return closest[1], closest[2]
