I have a file that will not zoom properly in details when displayed in parallel projection “isometric” views. It will zoom with the mouse wheel, or zoom dynamic button, then jump back to previous. Changing projection to perspective allows zooming but then resetting the projection back to parallel the zoom jumps back out again. Zooming extents or selected first does not help.
Zooming of planar views in the details works correctly.
I’m not seeing that here in a quick test. Does the “I have a file” part mean that this is limited to that file?
This is my test file: Isometric Detail.3dm (2.0 MB)
Also, please post the output from the SystemInfo command.
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 128GB)
.NET Framework 4.8.9290.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A4000 (NVidia) Memory: 16GB, Driver date: 9-13-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 553.09
Secondary graphics devices.
ASPEED Graphics Family(WDDM) (ASPEED) Memory: 64MB, Driver date: 5-15-2019 (M-D-Y).
> External USB display device with 0 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-13-2024
Driver Version: 31.0.15.5309
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
So far limited to this file, but the unique setup of projection mode, model extents and orientation is also limited. Let me know if you would want to have the file.
