Hi, im mechanical engineering without grasshopper knowledge and i want to use yoshimura pattern with curvature. i found a topic here with script here but i have problem and i’m not able to solve it. Here is problem and related topic.
Hi everyone,
I am trying to create a script for the yoshimura pattern (origami) and am stuck within my script. I have built up the script so it is completely parametric, starting off with the creation of a base module and then copying these into a pattern. Now copying in the x direction is easy since the kinematics remain the same, however copying to the y direction gives problems as when folding this pattern it automatically should fold into a barrel vault. This means there is a rotation neede…
im trying to do something like that
here is the script.
180808 Yoshimura Forum_re.gh (19.7 KB)
the problem
and this is how script look
sorry if it’s a basic problem. i’m not a grasshopper or rhino user
Adam_M
(Adam Mounsey)
October 4, 2018, 8:20pm
#2
Its strange, seems to be working here. I’m using Rhino 6 with the latest build.
I will try with 6. Thank you.
