Xnurbs test 3Dmodel
Hi @XNurbs,
I’m evaluating the purchase of your product because I use BlendSrf as main srf tool and I wish to see your tool in action.
This is a fast modelling so I didn’t took care of srf too much.
I wish to ask if you can patch the hole you see in the file to let me check the result.
2200603_Xnurbs_trial.3dm (5.9 MB)
Thanks
Riccardo
@skysurfer, Take a look at the file attached. I didn’t clean up any of the input geometry, just ran the XNurbs command and played a little with the settings. I wouldn’t consider this a perfect result, but given that the input geometry is 4 trimmed edges, I would say the result if very good.
XNurbs_Patch.3dm (4.5 MB)
Thanks for the answer!
I looked into it and seems quite clean for this input.
I’ll take in consideration.
Best
If I’m not mistaken, this example fails in Xnurbs (a Rhino blend surface can connect the two surfaces in continuity G2, Xnurbs does not).
Take a look for yourself.
xnurbs failed.3dm (372.4 KB)
