I am trying to use XL path for Bumblebee.
There is a possibility to define the actual file path where the excel data is read or written. Actually my problem is that even if I fill out the file path data or not, the data is always read from or written to the most front window of excel. So actually it makes no difference if it filled out or not.
Do I miss something?
did you find a solution to your issue?
no I did not.
