hi… i tried to write an excel sheet, but it is empty? why?
Moved to Grasshopper category.
I didn’t understand? Can you explain more.
He is telling you he changed the post category to Grasshopper, that is all.
okay
Since you haven’t uploaded a file, I can’t be sure, but it will be one of the following errors:
- The path has a “.” which is part of your name, I can’t remember which excelwriter as there are multiple different plugins with this functionality, but one of them doesn’t like it.
- The path is not a file, but looks like a folder.
- Your data may have a null value. You will want to replace the null with a blank value.
- The data structure may be horizontal, so you will have to put a flip matrix between entwine and Data input.
I had a null value in the data and the path was a folder.
Thank you
I arrived here because I couldn’t get the LunchBox ExcelWrite to work.
In my case, two of the column Headings had the same name, giving them unique names solved it.
