As for the grainy shadows, this can be fixed by increasing the skylight slider from 0 to 3-4
pls run _SystemInfo and post back the results. And from Rhino BETA, if you can run OptionsExport and send the .rhs to me I can at least verify if it something in the options itself or something else.
I don’t want the ambient occlusion smoother, I need it to be completely gone. A flat surface should have a single color just like in technical view modes in V8.
I could not get this to work, and even with “no lighting” I still see the ambient occlusion so I strongly suspect that it is a separate effect decoupled from any lighting but I can’t find the button to switch it off (without also turning of the shadows of the technical display mode).
This is what I get when I use scene lighting without sun and without skylight. Of course there is a slight shading effect depending on the orientation of the surfaces, but this is exactly what takes place in your “clean” example from Rhino8.
But imo that’s problematic, because when I then switch to rendered view, I have to open the lights panel and toggle those lights on… I still consider this a regression.
In V8, I can toggle between rendered and technical views with one click.
If either of the “lighting method” options “default” or “no lighting” looked like it does when you manually switch off all lights in the light panel, then I would have no complaints but they don’t. They both force ambient occlusion on which I still hope McNeel developers will consider as a bug.
