Wrong selection of VA Objects in different display modes
There is something wrong with selecting VA Objects in (I think all) display modes other than Hidden when the Cut Plane is toggled ON. This relates to both 3D and 2D view.
I’m using VA 2.12.3.15 and Rhino 7.16.22053
VA Selection problem.3dm (2.9 MB)
Hi @Czaja,
I can reproduce the issue here on my computer. Actually, this is not a bug with VisualARQ objects, as the same happens if you explode those objects into native Rhino polysurfaces. The problem is in the level cut plane. If I change it to a normal Rhino Clipping Plane, selection works fine, even with VisualARQ objects.
My first assumption is that Rhino is picking the clipped part of the wall, which will be the correct selection if no cut plane were enabled.
I don’t know why “Hidden” display mode works fine.
Thanks for reporting it. We’ll let you know when we fix this issue.
Enric
I think I may have found a current and very simple case of this issue with VisualARQ Columns.
When working in a Level view with the Cut Plane active, Columns cannot be selected using a standard Window Selection (left to right), even when they are completely inside the selection window.
In the same view, Walls are selected correctly with Window Selection.
Columns can still be selected using Crossing Selection (right to left).
If I disable the Cut Plane, Window Selection works correctly for the Columns as well.
So the issue seems specifically related to:
Column + Cut Plane + Window Selection
I can provide a simple test file if needed.
Environment: Rhino 8 SR34 (8.34.26223.11001) + VisualARQ 3.11.0.15030, Windows 11.
Hi @badileanu I could reproduce this issue. We will revise it and get back to you when we fix it.
@Czaja @badileanu I let you know that these “selection issues” reported here have been fixed in VisualARQ 3.12. RC2 is already available here: VisualARQ 3 - Version 3.12 RC2 released
