Wrong List sequence - Surface Split
Hey all,
I am trying to write a Grasshopper script for Stairs made out of two curves. I loft the 2 curves then divide the curves and use the points to get lines which split the surface. After that i want to move the single surfaces with a series along the Z vector. But somehow the order of the Surfaces got messed up after the Surface Split so the series doesn’t work well. I tried a lot of shifting and culling but couldn’t get a good result - Would be realy nice if you guys could help me fixing the order :wink:
Treppen.gh (15.7 KB)
I guess you’d better to shatter input curves rather than splitting the surface.
It seems that you forgot to internalise your input curves.
Treppen_re.gh (19.7 KB)
Surface Split is not the type of operation that guarantees or keeps order as it is not a type of command that is iterative, it happens all at once.
I have done it like that befor and it works well for a lot of different stairs but when you got a inner circle sourrended by a square both are divided in equal length with the konsequent that the stairs aren’t perpendicular to the circle - thats why i want to use lines to divide.
34tge
For the lines which divide to loft i used offset and and closest point to get those perpendicular lines on the loft.
Thanks, thats a good fact! I was realy confused why it came out mixed up.
Johannespetersen7,
So I approached it a little differently. Because the lines are in order, I picked line index 0 and index 1, then index 1 and index 2 etc. I then used those pairs to loft a surface which you can then move in the Z directions as needed. Not the cleanest solution, however it appears to work. Hope this helps.
Billmy version Treppen.gh (18.8 KB)
Try to check this plugin if those components wouldnot allow you different strategy Sasquatch Utilities | Food4Rhino
Mahdiyar,
I like your solution, super clean and easy. Thanks for sharing.
Bill
Try this with shift by 2 and reverse curves list input
That works well for this particular situation but it would be nice to have a more general solution. I could probably creat such a solution with more operation for curves…
Do you guys know a plugin with more curve operation beside pufferfish?
You can sort surfaces centers along curve
I think this work with various situations
Treppen.gh (14.1 KB)
Thanks a lot Seghier! that is exactly what i was looking for :slight_smile:
