tiralinies
(Tiralinies)
December 11, 2018, 6:58pm
1
Hi all!
I just re-installed the last version of Rhino 6 to solve this issue but did not work.
does this happened to any of you, do you any solution?
here my SystemInfo data:
Rhino 6 SR10 2018-11-7 (Rhino 6, 6.10.18311.20531, Git hash:master @ 0f9089a0035dcc6955732d57071445ecc29390f0)
Licence type: Educational Lab License, build 2018-11-07
License details: Cloud Zoo. In use by: Pep (MPDA)
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: BU
Intel® Iris™ Pro Graphics 5200 (OpenGL ver:4.3.0 - Build 20.19.15.4835)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.3
Shading Language: 4.30 - Build 20.19.15.4835
Driver Date: 10-16-2017
Driver Version: 20.19.15.4835
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Geometry Gym\Rhino3d\ggRhinoIFC.rhp “ggRhinoIFC” 1.6.66.0
C:\Program Files\Geometry Gym\Rhino3d\ggRhinoRobot.rhp “ggRhinoRobot” 1.2.16.0
C:\Program Files\Geometry Gym\Rhino3d\ggRhinoSAP.rhp “ggRhinoSAP” 1.3.26.0
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.10.18311.20531
C:\Program Files\Geometry Gym\Rhino3d\BullAnt.rhp “bullant” 1.4.5.0
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.10.18311.20531
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 6.10.18311.20531
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.10.18311.20531
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.10.18311.20531
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.10.18311.20531
MANY THANKS
I’m assuming that’s the default mesh sphere correct? Radius=10, origin (0,0,0) and all that?
If that Rendered display mode you’re in? Shaded, Wireframe, …?
tiralinies
(Tiralinies)
December 11, 2018, 8:33pm
3
wireframe
but happens with the other renderers too
Thanks, I logged a new item under RH-49915 .
nathanletwory
(Nathan 'jesterKing' Letwory)
December 11, 2018, 8:38pm
5
@tiralinies does it still happen after disabling the third-party plug-ins and Rhino restart?
tiralinies
(Tiralinies)
December 11, 2018, 8:46pm
6
Thank you very much!
I’ll follow the discussion
tiralinies
(Tiralinies)
7
Did not
you mean all Grasshopper plugins?
( I wish I don0t have to do that… hopefully)
stevebaer
(Steve Baer)
December 11, 2018, 11:06pm
8
@DavidRutten is there any way to start grasshopper without loading any external components? This would help eliminate any possibility that something we didn’t write is interfering.
DavidRutten
(David Rutten)
December 11, 2018, 11:37pm
9
Sort of. You can run the LoadGrasshopperOneByOne command and then say “no” to all plugins.
stevebaer
(Steve Baer)
December 11, 2018, 11:58pm
10
@tiralinies can you restart Rhino/Grasshopper and try David’s LoadGrasshopperOneByOne command that he describes above? This will help us eliminate an possibility that an external component is somehow causing this effect.
tiralinies
(Tiralinies)
December 12, 2018, 10:47am
11
I did as you and David suggested and loaded Grasshopper with the inhouse pluguins and now the shader is fine, and now opened a fully loaded Grasshopper (with all the pluguins) and the shader is working fine again…
I will let you know if the problem persists or re-appear (and try to figure out why that happened)
many thanks for the help
Same happened here. This is the ghosted view on Rhino. I have already Restore to defaults but nothing happens. Any suggestion?
nathanletwory
May 23, 2020, 5:00pm
13
Looks pretty much like driver issue, here a recent thread with similar looking issue. See if suggestions here help:
[Capture]
I have a display or a render error. I don’t know what is causing this. It started about 4-5 months ago and its slowly getting worse. I have downloaded Rhino 6 again nothing changed. My computer is a Mac I am using rhino in Bootcamp.
Thanks @nathanletwory ! Just updated video card driver and its fine now.
Same here: Windows at Bootcamp (Iris Pro 5200)
