Enabled clipping planes in attached files in Worksession cannot be deactivated. If a file is attached and it contains an enabled clipping plane that clipping plane will affect all geometry. The only way to disable the clipping plane is to switch the active file, wait for all the attached files to reload, find the enabled clipping plane and disable it. If the enabled clipping plane is in another file then the you have to switch the active file again, wait again for all the attached files to reload, find the enabled clipping plane and disable it. Repeat until the enabled clipping plane is found and disabled. Then switch the active file back to the file being worked and wait again for all the active files to reload.
A method to disable clipping planes in attached but not active files is needed.
Example files:
File 1.3dm (2.8 MB)
File 2.3dm (3.3 MB)
WS Example A.rws (656 Bytes)
Open the worksession file.
Note that File 2 is the active file and does not contain a clipping plane.
File 1 is attached and contains a clipping plane which is clipping geometry in the perspective window.
Try to disable the clipping plane.
Rhino 7 SR7 2021-5-31 (Rhino 7, 7.7.21151.13001, Git hash:master @ 24d76fc798fa6ffd33733e5f18b034d547b87840)
License type: Commercial, build 2021-05-31
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 5-6-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.59
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-6-2021
Driver Version: 27.21.14.6259
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
C:\Program Files\Orca3D V2\Orca3D.rhp “Orca3D” 2.0.21.0
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.2\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.2.0
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.0\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.0.0
D:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.7.21151.13001
D:\Program Files\Rhino 7\Plug-ins\rdk.rhp “Renderer Development Kit”
D:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.7.21151.13001
D:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.7.21151.13001
D:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
D:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp “Snapshots”
D:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.7.21151.13001
D:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.7.21151.13001
D:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
D:\Program Files\Rhino 7\Plug-ins\Displacement.rhp “Displacement”
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.21.831\SectionTools.rhp “SectionTools”
