I place a clipping plane and it has disappeared and I can not turn it off, now half of my file is missing. I tried to do selClippingplane but it didn’t work. Help would be much appreciated.
Hi Shaun -
That clipping plane is bound to be somewhere, possibly on a layer that is off.
If you can’t find it, it’d be interesting to get the 3dm file.
Apart from that, running 4View
two times will probably make all views not-clipped. You can also run the NewFloatingViewport
when the clipped view is active. That will make a new viewport that is not clipped. You can then save that viewport as a Named View and use that name in the original non-floating clipped viewport.
