Hello the Internet,
I’m working with a pretty large environmental model that’s made out of mesh. What I need to do is to move some of the point in order to change the terrain. Now to activate controlling points, I’d need to convert it into NURBS, problem beeing: the model contains approximately 800’000 meshs … Whenever I try to convert it, Rhino crashes because of the large scale. Any suggestions what I could do?
The file is pretty big so I couldn’t attach it, but below you’ll find the link to dropbox and the .3dm, thank’s in advance for any help!
kind regards, Miro
You do not need (or want) to convert your terrain to NURBS in order to manipulate it via control point editing. Just turn on points for the mesh in the same way you would for curves/surfaces and edit away. You might want to look at the command SoftMove on groups of control points to get them to move together with falloff.
You could use the command ReduceMesh and see if you can’t get the mesh to a managable size.
You could use the Drape command to drape a NURBS surface over the mesh and edit the surface
In both cases you will lose some fidelity, the NURBS surface will smooth over detailed areas more than the mesh reduction will I think, but I don’t know what your end goal is.
I’m working with huge landscape meshes every now and then and I need to edit and reduce them. What I typically do is extrude a rectangle around my area of focus and split my terrain with meshsplit (works > 1M vertices), then I can use reduce mesh on the external part far away from my site and I can use edit control points on the bit close to my site.
