With Python Script Model Space Scale Change
How to change Model Space Scale value with Python Script?
Model Space Scale: 1
Hi @ska_drivers,
Review the following code and let me know if you have any questions.
import Rhino
import scriptcontext as sc
import System
def TestOverrideDimensionScale():
    filter = Rhino.DocObjects.ObjectType.Annotation
    rc, objref = Rhino.Input.RhinoGet.GetOneObject("Select text", False, filter)
    if not objref or rc != Rhino.Commands.Result.Success:
        return
    text = objref.TextEntity()
    if not text:
        return
    dim_style = text.DimensionStyle
    new_name = sc.doc.DimStyles.GetUnusedStyleName(dim_style.Name)
    override_style = dim_style.Duplicate(new_name, System.Guid.Empty, dim_style.Id)
    override_style.DimensionScale = dim_style.DimensionScale + 1.0
    override_style.SetFieldOverride(Rhino.DocObjects.DimensionStyle.Field.DimensionScale)
    new_text = text.Duplicate()
    new_text.SetOverrideDimStyle(override_style)
    sc.doc.Objects.Replace(objref, new_text)
    sc.doc.Views.Redraw()
if __name__ == "__main__":
– Dale
Thank you. :slight_smile:
Hello, what if I replace the text with annotations? Which part of the code changes will work?
Hi Dale,
How can we do this with RhinoScript instead of Python?
(VbScript)
Hi @ska_drivers,
This operation is not supported by legacy RhinoScript - sorry.
– Dale
Your code only works with text. If I want to change the model space scale for the dimension, it will not work. Is there any way to handle this issue with dimensions? Thank you.
Hi @theanhkc07,
Supporting any annotation isn’t that much different.
#! python3
import Rhino
import System
    rc, objref = Rhino.Input.RhinoGet.GetOneObject("Select annotation", False, filter)
        return
    annotation = objref.Geometry()
    if not isinstance(annotation, Rhino.Geometry.AnnotationBase):
        return
    dim_style = annotation.DimensionStyle
    new_annotation = annotation.Duplicate()
    new_annotation.SetOverrideDimStyle(override_style)
    sc.doc.Objects.Replace(objref, new_annotation, False)
– Dale
