Hi @aws, below example change a dimension’s model space scale value to 2.5
using IronPython in Rhino 7:
#! python 2
import Rhino
import scriptcontext
def DoSomething():
dim_id = rs.GetObject("Dimension", rs.filter.annotation, True, False)
if not dim_id: return
dim_obj = rs.coercerhinoobject(dim_id, True, True)
if not isinstance(dim_obj, Rhino.DocObjects.DimensionObject): return
dim_obj.Geometry.DimensionScale = 2.5
dim_obj.CommitChanges()
scriptcontext.doc.Views.Redraw()
DoSomething()
_
c.
I am very grateful to you, this problem has troubled me for about half a month
