Couple of ideas I would like Rhino3D to do (maybe its already available)…
Click on the layer list and extract "%<LayerName(“xxxx”)>% as a copy option to then paste in a text box
In the layouts list have additional fields for users to enter data ie version number and a date plus have a filter system to hide (grey text) certain values ie date before 3rd Jan 2024 or “checked by”. This enbles filtering when generating a series of PDF saves and for general viewing. Such data is also transferable as %<LayoutField1(“xxxxxx”)>%
When generating leaders an option to extract the layer name of the part or block name into the leader text box.
When opening the block the window appears with all the nested blocks. Is there a shortcut to retract all the blocks? Quite a task having to constantly scroll up and down and then start again up and down
Thank you so much for helping me on this one. It does exactly what Im looking for the only problem now Im new to scripts and trying to create a shortcut but its failing. Are you able to point me in the right direction? I did try this… Rhino - Running a Python script in Rhino(.,The%20Python%20script%20will%20run.
however it does not work.
Ive got the shortcut to open the explorer. Is it possible to preload the script so the one click does all or does one have to navigate to the py file each time?
Lets say have an indoex page showing 5 preview windows of selected layout pages.
Sync Viewports - I have two viewports on different layout pages. I want to hide certain data in a viewport and doing so automatically copies the view and detail on/off on the selected sync viewports
ok lets say you nest three circles each set in its own block instance. Now go to the layout with a viewport showing the block instances nested. I would like to use the leader and extract the individual block names of the circles.
So in the layout list you have the page names and page size. I would like to see some extra features for instance the yellow column have input text “pending, approved, in progress”. Red column user name and green a date. the search bar gives an option which column to search in and list those pages.
Another useful feature a hide page button - very useful when generating pages and pages into one page doc
