I’m playing around with F4 hotkey to cycle through the 4 gumball alignment options.
This is handy but could be improved if the user had visual confirmation of which mode is chosen. I know we can click on the bunny tail to see that, but the whole point of the shortcut is to avoid going through this menu.
The easiest way I can think of is to have a prompt in the command line “Gumball Mode switched to XXX” after the command is run.
Right now it’s confusing because it’s indicating the previous value between brackets.
Or a temporary display on the gumball with a letter (C, W, V, O) ?
