I’d like to suggest an Optimize command for SubD objects
When editing SubD geometry, especially after operations such as Bridge, Stitch, or Append Faces, coincident vertices or edges may remain disconnected, sometimes producing unexpected surface deformations.
Currently, Stitch can resolve these issues, but it requires manually identifying and selecting the affected vertices or edges.
It would be useful to have a single command that automatically:
Welds coincident vertices within a user-defined tolerance.
Stitches compatible coincident edges where possible.
Removes degenerate or unused geometry, where applicable.
Ideally, the default tolerance could be 0, affecting only exactly coincident vertices, with the option to specify a larger tolerance when needed.
The goal is to clean up SubD topology without manually searching for disconnected vertices or performing multiple operations.
I’ve tested AlignVertices, but it only adjusts vertex positions without actually welding them.
What I’m looking for is automatic welding of coincident SubD vertices within a specified tolerance, including stitching compatible edges where possible.
Let’s hope so! I’ve tested it in Rhino 9 Beta, but for now it still doesn’t weld the vertices.
Adding a Weld=Yes/No option to AlignVertices would be a nice solution too.
@badileanu I just tried this in Rhino 9, it does weld SubD vertices. However, it only works for vertices of the control polygon, that are close to each other in the control polygon (i.e. what you see in box mode for SubD display).
If you get a chance to try again and still find that it does not work like you would want it to, please upload a 3dm file to reproduce the issue, and show the exact options you are using in AlignVertices.
I’ve attached a 3DM file with three examples: the original geometry, the result after AlignVertices, and the desired result after manually applying Stitch.
All surfaces already belong to the same SubD object.AlignVertices correctly aligns the vertices, but they remain topologically disconnected.
Since AlignVertices already has a distance tolerance, perhaps a simple Weld=Yes/No option could automatically weld aligned vertices and stitch compatible edges.
This would eliminate the need for manual stitching, which becomes impractical with complex SubD geometry.
C:\Users\badil\AppData\Roaming\D5 Lite for Rhino\engine\D5Conv.Rhino8.rhp “D5 Live Sync for Rhino”
C:\Program Files\Rhino 9 WIP\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 9 WIP\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
@badileanu Thanks for the detailed example, I can reproduce it here and have logged a ticket for the developer to fix it: RH-100067 AlignVertices: Moves but doesn’t weld SubD vertices
