Wish: SelSkipped
@wim may you add this to the wishlist. When exporting to DWG, we get the below command history. I would like to select the skipped objects. In order to know which objects they are and fix them. The usual checks like SelBadObjects etc. don’t return anything suspicious.
Thanks!
Could this be as simple as just having an option to check in the export command that will cause it to write each skipped object’s identifier in a “skipped” line for each one that’s skipped?
Hi Silvano -
We’d rather understand why those aren’t exported and fix that. Could you please post or upload a file that shows this behavior?
Sent you a DM with the file.
As a side note, this is happening frequently with DWG export with all types of files.
AIW’s suggestion would also work for us.
