Trimming/Boolean Solids
Hello all! I am semi new to rhino, and need some help here. I created these two surfaces, then extended and capped them into polysurfaces. They are intersecting and i want to trim or boolean somehow so that those pieces are not sticking out, it should just look like a gable. It would be great if that i could trim the pieces so that they will create angles that line up to the center line, as i will be laser cutting this later!
Thanks
Hello - the devil’s in the details, so posting your objects in a Rhino file may be best but using one to trim the other and then vice-versa may get you what you need.
@idoberenz - To upload -
HausGablesisolate.3dm (11.0 MB)
Thank you, i uploaded the link to my file. I have tried to trim, but when i do this, it deletes the surfaces.
Hello - your roof parts are slightly skewed from one another if you look closely:
if that is intentional, then you’ll need to use Intersect to find a curve of intersection and trim the objects with that - it might be tricky to trim the right bits - but since you say that you want to trim off the parts that stick out, I’ll assume you really want this to be a clean intersection.
The really the best thing to do is to make a V-shaped closed polyline and ExtrudeCrv - done!
If you have two cleanly intersecting slabs, that you want to clean up then you can splt or trim with a bisecting plane - CutPlane is a good way to make one of these or use the InfinitePlane:
Trim using a CutPlane. This makes an actual plane in the file that you can select and use as a trimming object. You can then delete the plane:
Trim using a vertical ‘InfinitePlane’ Notice I type ‘ip’ when prompted by Trim for the cutting objects, then Vertical and then I set the plane using the ‘Int’ Osnap. Iinfinite Planes are temporary, only for the one command then they disappear.
Wow this was so helpful thank you so much! This was exactly what i was trying to do :smile:
