Wish: Native parametric Ramp object
VisualARQ currently doesn’t provide a native parametric tool for creating architectural ramps.
A ramp should be definable by its path, direction, width, start/end elevations (or slope), thickness and landings, with proper 2D plan representation, following the same cut/overhead logic as stairs, with the portion above the cut plane displayed as overhead. It should support the usual configurations, such as straight, L-shaped and curved/circular ramps. Railings would also be welcome.
Whether this is implemented as a dedicated Ramp object or by extending the existing Stair object is an implementation detail.
The Villa Savoye sample itself is a good example where this functionality would be useful, since its ramps currently need to be modeled using other VisualARQ/Rhino geometry.
@badileanu Thanks for this request. We will take these comments into account when we implement a new ramp object in future VisualARQ versions.
